Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Q: How to test ACTX_01
6 REPLIES 6
mingway
896 Views, 6 Replies
Dear All
I want to test ACTX_01 (Interactive Review NWD model)
But always show need install activex control...
Does anyone can help me ?  Thanks
OS:WIN 7 64bit
IE 8
AP: Office 2010、AutoCAD 2012、REVIT ARCHI 2012、Navisworks Manager 2012
Mingway
Product Support Manager
Concord Tech Co, Ltd. 協勤資訊有限公司
LinkedIn
6 REPLIES 6
bbrown
in reply to: mingway
Try opening the file in Internet Explorer 64bit
mingway
in reply to: bbrown
Hi bbrown
It's work !
Thank you very march
Q2, If i want all user test this funtion in my web site(xp,vista,win7 & 32bit,64bit)
How can i do?
Already copy my C:\Program Files\Autodesk\Navisworks Manage 2012\api\COM folder to my website
http://192.168.1.120/COM64
at now , use IE 64 can see it
But in 32bit OS, still have problem,even i create another COM folder for 32bit (copy x86 COM folder to http://192.168.1.120/COM86)
Autodesk_Navisworks_Manage_2012_Multilingual_Win_32bit\x86\NAVMAN\Autodesk\Navisworks Manage 2012\api\COM
Do you have any solution ?
Mingway
LinkedIn
bbrown
The COM folder doesn't make the difference. For it to work, a user has to match the Navisworks ActiveX Redistributable Setup.exe executable to their system, so a 32bit OS must install the 32bit executable and open the website in a 32bit browser (which is their only choice really), and a user with 64bit OS must install the 64bit executable and open the website in a 64bit browser (IE 64bit). Your problem is most likely that you don't have a 32bit executable file since you copied it from your 64bit OS. It's confusing, but there are two different versions of that executable both labeled the same. You know which one you have based on the OS that Navisworks was installed on.
I had to install Navisworks Manage in trial mode on a 32bit OS to get a copy of the 32bit executable for my testing purposes. Hope that helps.
mingway
in reply to: bbrown
Thanks bbrown
I do some test
Use VirtualBox make an XP 32bit OS for test
Install navisworks manage 2012 32 bit and run with trial mode
When open ACTX_01,It's show install activex..
down&installed , still can't see the model....
so i re-post the question...
Mingway
LinkedIn
bbrown
Other then making sure you've got an up to date version of IE and are allowing ActiveX to run, I don't know why that wouldn't be working.
mingway
in reply to: bbrown
IE plug-in default install to C:\Windows\Downloaded Program Files
In my case
WIN 7 64bit can see Navisworks ActiveX Redistributable Setup.exe in this directory
But XP 32 bit only have Shockwave Flash Object (Even manual install Navisworks ActiveX Redistributable Setup.exe 32bit)
and on XP 32 bit , I can't copy/paste file to C:\Windows\Downloaded Program Files directory
I will find more about IE plug-in infomation...
Thanks for your help
Mingway
LinkedIn
Rail Community
