Properties from ActiveX
bbrown
bbrown
Is it possible for the ActiveX control to expose object properties? For example the layer name of a selected object (from DWG file) inside the NWD file?
xiaodong_liang
Autodesk Support
Autodesk Support
I just replied some relevant information on another post.
http://forums.autodesk.com/t5/Autodesk-Navisworks-API/Embedded-links-with-ActiveX/td-p/3252320
Hope it helps.
Xiaodong Liang
Developer Technical Services
bbrown
Sorry again, I meant for this question to reference the Redistributable API. Is it possible with that?
xiaodong_liang
Autodesk Support
Autodesk Support
Sorry, the answer is no.
