Override Transform Rotation API
joseph_sarmiento
joseph_sarmiento
Please help me to modify my code. What I need is to change the rotation value not only one time.
I saw a code on youtube and I tried  to modified it according to my needs.
here is  my code snippet.
        public void SetRotation(Document document, ModelItemEnumerableCollection modelItems, Rotation rotation, string modelPath)
            foreach (var item in modelItems)
                var loc = item.BoundingBox().Center;
                var mb = new Vector3D(loc.X, loc.Y, loc.Z);
                var mo = new Vector3D(-loc.X, -loc.Y, -loc.Z);
                var transVec = Transform3D.CreateTranslation(mo);
                Autodesk.Navisworks.Api.Application.ActiveDocument.Models.OverridePermanentTransform(new List<ModelItem> { item }, transVec, true);
                var rt = new Rotation3D(new UnitVector3D(rotation.x, rotation.y, rotation.z), (((rotation.angle) * (Math.PI / 180)) / 2));
                var tr = new Transform3D(rt, mb);
                Autodesk.Navisworks.Api.Application.ActiveDocument.Models.OverridePermanentTransform(new List<ModelItem> { item }, new Transform3D(tr), true);
this works only one time when I run or click again my plugin the result is wrong.
because maybe there are wrong in the computation or matrix.
Thank you!
arautio
You are most likely adding transforms on top of previous transforms every time you run your code.
joseph_sarmiento
Thank you it works.
