I imported my files from Revit into Navisworks. The selected tree structure is fixed and cannot be changed.I try to change porperty.Value , But not modifiable.I need to render the selection tree of Navisworks based on the data I entered in Revit.
I've seen someone implement choice tree structural refactoring as below:
But I don't know how to do that.like below
Please help me. Best wish !
Hi @piyinghai ,
To the best of my knowledge, it is not possible to modify the Model Tree hierarchy in Navisworks. However, you can sort the existing Model Tree hierarchy or create a custom selection tree.
Please refer to the following links for more information:
Thanks for your reply, I need to have a try. Before that, I would like to ask if the results achieved by this article are as follows, is it the result under the standard mode of Navisworks' selection tree?
Hi @piyinghai ,
In your previous post, the attached image shows that I simply selected the standard mode and sorted the selection tree in ascending alphabetical order.
