Navisworks Viewer Properties?
brian.k.smith
brian.k.smith
Dear NW API Developers:
Is the relationship between the Navisworks Object model and the structure of the Viewpoints XML file documented?
I am trying to create a plug-in that will write only selected ‘branches’ of the SavedViewpoints ‘tree’ to an XML file.
Some properties are written to the XML file (such as “terminal_velocity”) which I cannot find in the VS Object Browser.
Thank you for any help that you can provide!
xiaodongliang
Hi Brian,
I did not find an API that corresponds to this property. There are some properties named with 'speed' in a viewpoint object, but after some testing, it looks none of them are related with terminal_velocity.
I will double check.
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Brian,
our engineer told me:
The "terminal_velocity" is just an internal value that you cannot edit in the UI or via the API. It looks like it is hard-coded at 50m/s. If the customer wants to write their own viewpoint XML, then they should set it to something similar (taking into account current world units).
