Navisworks '25 Custom Properties Crashing (COM API)
ChristianMolino
ChristianMolino
I have an addin that pulls data from an excel sheet and then uses it to populate custom properties on various model items. It works great in Navis '24, but in Navis '25 I am getting a crash when it tries to run the command "propn.RemoveUserDefined(index)". Did something change in the navis '25 COM API that would be causing this? Or could it have something to do with the changes that were made to the category organization in '25?
Here is a clip of the block that crashes
                // Remove existing "PieceTracker" attributes if they exist
                int index = 1;
                foreach (ComApi.InwGUIAttribute2 attribute in propn.GUIAttributes())
                    if (attribute.UserDefined && attribute.ClassUserName.Equals("PieceTracker"))
                        propn.RemoveUserDefined(index);
                        break;
                    index++;
and here is the whole method
        // This method handles updating properties for a found item
        private void ProcessModelItem(ModelItem foundItem, ExcelEntry excelEntry, DateTime excelLastModifiedDate)
            // Convert .NET item to COM
            ComApi.InwOpState10 oState = ComApiBridge.State;
            ComApi.InwOpSelection comSelectionOut = ComApiBridge.ToInwOpSelection(new ModelItemCollection { foundItem });
            foreach (ComApi.InwOaPath3 oPath in comSelectionOut.Paths())
                ComApi.InwGUIPropertyNode2 propn = (ComApi.InwGUIPropertyNode2)oState.GetGUIPropertyNode(oPath, true);
                int index = 1;
                        break;
                    index++;
                // Create a new property category
                ComApi.InwOaPropertyVec newPvec = (ComApi.InwOaPropertyVec)oState.ObjectFactory(ComApi.nwEObjectType.eObjectType_nwOaPropertyVec, null, null);
                // Add properties from Excel data
                AddProperty(oState, newPvec, "Mark Number", excelEntry.MarkNumber);
                AddProperty(oState, newPvec, "Req Qty Pieces", excelEntry.ReqPieces);
                AddProperty(oState, newPvec, "Setup Date", excelEntry.SetupDate);
                AddProperty(oState, newPvec, "Req Draw Date", excelEntry.ReqDrawDate);
                AddProperty(oState, newPvec, "Req Coord Date", excelEntry.ReqCoordComplete);
                AddProperty(oState, newPvec, "Coord Complete Date", excelEntry.CoordComplete);
                AddProperty(oState, newPvec, "Coord By", excelEntry.CoordBy);
                AddProperty(oState, newPvec, "Mech Complete", excelEntry.MechComplete);
                AddProperty(oState, newPvec, "Elec Complete", excelEntry.ElecComplete);
                AddProperty(oState, newPvec, "Plumb Complete", excelEntry.PlumbComplete);
                AddProperty(oState, newPvec, "Fire Complete", excelEntry.FireComplete);
                AddProperty(oState, newPvec, "Arch Complete Date", excelEntry.ArchComplete);
                AddProperty(oState, newPvec, "Coord Comments", excelEntry.CoordComments);
                AddProperty(oState, newPvec, "Weeks Until Due", excelEntry.WeeksDue);
                AddProperty(oState, newPvec, "*Navisworks Last Updated", DateAndTime.Today.ToShortDateString());
                AddProperty(oState, newPvec, "*Excel Last Updated", excelLastModifiedDate.ToShortDateString());
                // Add the new category to the object
                propn.SetUserDefined(0, "PieceTracker", "PieceTracker", newPvec);
Elie_Trad
Nothing changed, same code am using on 2023 and 2024 is working on 2025, did you miss by any chance adding the References of ComApi 2025 instead of 2024?
ChristianMolino
same exact references I use on other versions 😐 I feel like maybe something changed on the backend with how Navisworks indexes the categories, but I have no clue where to find documentation on that.
