Navisworks 2020: Access Timeliner Play/Stop buttons from API
guiliang_2000
guiliang_2000
Is there any possibility to access Timeliner Play/Stop buttons from the API?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @guiliang_2000 ,
The Play button just executes Autodesk.Navisworks.Api.Interop.LcTlSimulationHelper.Instance.Play() and the Stop button just calls Stop() in the same object.
This class is exposed in Autodesk.Navisworks.Timeliner.dll
Since it is in an
Interop namespace, it comes with no guarantees or documentation.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
guiliang_2000
Thank you very much!✌️
