Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Naviswork Manage 2024 Error Report
7 REPLIES 7
Message 1 of 8
Krishnan_VinothkumarF7LMX
1260 Views, 7 Replies
Date/Time: 2023-09-06 17:04:14 +08:00
Application: Roamer.exe
Error: CLR exception - code e0434352 (first/second chance not available)
Crashed Module Name: mscorlib.dll
Exception Address: 0x00007ffbfc41cf19
Exception Code: e0434352
I cannot save the file automatic come error when go to save the file
Tags (1)
7 REPLIES 7
Message 2 of 8
Hi @Krishnan_VinothkumarF7LMX ,
Submit the error report.
After submitting the error report, please send me the CER report id/number.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-Reporting.ht...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
Hi @naveen.kumar.t ,
I am getting the same issue. I attached the screenshot alongside with the error report (.xml only, .dmp folder can't be attached below). I have contacted support under Case no.: 22316283. Really appreciate help as I have tried uninstalling and reinstalling, deleting navisworks from the autodesk folder and registry editor. The issue keeps persisting.
Message 4 of 8
Hi @ali_jafferali ,
I am unable to locate the Error Report ID. Am I overlooking something here?
You will find the Error Report ID once you click the 'Send Report' button located at the bottom of the error report.
The Error Report ID will assist me in analyzing the issue on our end.
Naveen Kumar T
Message 5 of 8
@naveen.kumar.t ,
When I click send report I get a connection time out, and it mentions, your report was not sent. Screenshot below (image 3). I can send the error report .dmp file, but it cannot be attached below. Is there other means I can send it?
Message 6 of 8
Hi @ali_jafferali ,
The report may contain confidential information. Please download the ".xml" and ".dmp" files by clicking "View report contents" and send them to me privately via message.
Naveen Kumar T
Message 7 of 8
s224614312
in reply to: naveen.kumar.t
Hi @naveen.kumar.t
Hope you are well. I have the same error. Could you please help and solve it
error code: 762359339
Date/Time: 2024-05-19 12:51:43 +10:00
Crashed Module Name: Autodesk.Navisworks.Api.dll
Exception Address: 0x00007ffc7219543c
Message 8 of 8
naveen.kumar.t
in reply to: s224614312
Hi @s224614312 ,
I can't provide too much information.
You opened 2024_Hospital_Architectural.nwd, and it tried to load a Quantification database, but that failed.
I have no idea what might have caused this.
Naveen Kumar T
Rail Community
