Is it possible to detect the currently selected ClashResult / ClashResultGroup?
jonathonbroughton
jonathonbroughton
Even if it is a process of checking for a property of isSelected from all the results. Thanks
xiaodong_liang
Autodesk Support
Autodesk Support
I seem not to find such API. you may probably try to compare the current viewpoint with that of ClashResult, yet this is not reliable because two results can have same viewpoints.
the blog on how to get viewpoint of clash (using COM because .NET API has not exposed it)
http://adndevblog.typepad.com/aec/2012/09/workaround-to-export-image-of-clash-result.html
