I’m developing a plugin for Navisworks using the .NET API and need to retrieve the Autodesk user ID of the currently signed-in user. This is required to validate their subscription or license status using the Entitlement APIs.
However, I couldn’t find any specific reference to Navisworks in the Entitlement API documentation—it only mentions AutoCAD, Revit, and Inventor.
I attempted to use the following code, but it doesn’t return the correct user ID:
private static string GetUserId() { string userId = string.Empty; Autodesk.Internal.InfoCenter.InfoToolbar autodeskInformaton = ComponentManager.InfoCenterToolBar; for (int i = 0; i < autodeskInformaton.Items.Count; i++) { if (autodeskInformaton.Items[i] is Autodesk.Internal.InfoCenter.WebServicesLoginButton) { userId = (autodeskInformaton.Items[i] as Autodesk.Internal.InfoCenter.WebServicesLoginButton).Text; } } return userId; }
Is there a proper way to retrieve the signed-in Autodesk user ID in Navisworks to use with the Entitlement APIs? Any help or alternative suggestions would be greatly appreciated.
