How to Retrieve the Signed-In User ID in Navisworks for Use with Entitlement APIs?
tarekahmed136
tarekahmed136
I’m developing a plugin for Navisworks using the .NET API and need to retrieve the Autodesk user ID of the currently signed-in user. This is required to validate their subscription or license status using the Entitlement APIs.
However, I couldn’t find any specific reference to Navisworks in the Entitlement API documentation—it only mentions AutoCAD, Revit, and Inventor.
I attempted to use the following code, but it doesn’t return the correct user ID:
private static string GetUserId()
    string userId = string.Empty;
    Autodesk.Internal.InfoCenter.InfoToolbar autodeskInformaton = ComponentManager.InfoCenterToolBar;
    for (int i = 0; i < autodeskInformaton.Items.Count; i++)
        if (autodeskInformaton.Items[i] is Autodesk.Internal.InfoCenter.WebServicesLoginButton)
            userId = (autodeskInformaton.Items[i] as Autodesk.Internal.InfoCenter.WebServicesLoginButton).Text;
    return userId;
Is there a proper way to retrieve the signed-in Autodesk user ID in Navisworks to use with the Entitlement APIs? Any help or alternative suggestions would be greatly appreciated.
tarekahmed136
The provided code retrieves the text from the textbox in the Navisworks toolbar, but this text does not necessarily represent the user ID.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @tarekahmed136 ,
This code uses the Navisworks API to access the username and user ID of the currently signed-in user.
string userName = Autodesk.Navisworks.Api.Application.Gui.SignInUserName;
string userId = Autodesk.Navisworks.Api.Application.Gui.SignInUserId;
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
