How to retrieve the "Phase Created Name" property from the selection tree using the Navisworks API
VanQuyet.Doan
VanQuyet.Doan
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @VanQuyet.Doan ,
Please take a look at this below link
https://forums.autodesk.com/t5/navisworks-api/how-to-get-all-properties-under-a-propertycategory-fro...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
VanQuyet.Doan
I made a loop through the objects and select the first one, but it throws the error "object reference not set to an instance of an object". Can you help me test the code?
using System;
using System.Collections.Generic;
using System.Windows.Forms;
using System.Text;
using Autodesk.Navisworks.Api;
using Autodesk.Navisworks.Api.Plugins;
namespace NavisworkApiSample
    public class B1 : AddInPlugin
        public override int Execute(params string[] parameters)
            // current document
            Document doc = Autodesk.Navisworks.Api.Application.ActiveDocument;
            // display message
            StringBuilder message = new StringBuilder();
            //Create a new search
            Search s = new Search();
            //set the selection to everything
            s.Selection.SelectAll();
            //Add a search condition
            s.SearchConditions.Add(SearchCondition.HasCategoryByName(PropertyCategoryNames.Geometry));
            ////get the resulting collection by applying this search
            //ModelItemCollection searchResults = s.FindAll(Autodesk.Navisworks.Api.Application.ActiveDocument, true);
            ModelItem item = s.FindFirst(Autodesk.Navisworks.Api.Application.ActiveDocument, false);
            if (item != null)
                // make selection
                doc.CurrentSelection.Add(item);
                // get modelitem's Element category by display name method
                PropertyCategory elementCategory = item.PropertyCategories.
                    FindCategoryByDisplayName("Element");
                // all properties of Element category
                DataPropertyCollection dataProperties = elementCategory.Properties;
                // display properties count
                message.Append(String.Format("[{0}] ModelItem's Element Category has {1} Properties.\n",
                    Id.ToString(), dataProperties.Count));
                // index
                int index = 1;
                // iterate properties
                foreach (DataProperty dp in elementCategory.Properties)
                    // append to display "Property Display Name & Property Value(includes DataType)"
                    message.Append(String.Format("{0}. {1} => {2}\n", index, dp.DisplayName, dp.Value));
                    // index increment
                    index += 1;
                // display message
                MessageBox.Show(message.ToString(), "Element Category");
            return 0;
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @VanQuyet.Doan ,
I think you are facing an issue on this line
PropertyCategory elementCategory = item.PropertyCategories. FindCategoryByDisplayName("Element");
Please check whether the PropertyCategory with the display name "Element" is present in the PropertyCategories or not.
I need some more details to analyze this issue further.
Naveen Kumar T
VanQuyet.Doan
hi @naveen.kumar.t ,
Thank you for your response, it completely solved the problem I was having. The PropertyCategory named "Element" was not present in the PropertyCategories collection. Since then, I have corrected the search condition.
using System;
using System.Text;
    public class SearchModelItemAndCollectProperties : AddInPlugin
            // current document
            // display message
            Search search = new Search();
            search.Selection.SelectAll();
            search.SearchConditions.Add(SearchCondition.HasPropertyByDisplayName("Element", "Id"));
            ModelItem item = search.FindFirst(Autodesk.Navisworks.Api.Application.ActiveDocument, false);
            if (item != null)
                // make selection
                // index
                int index = 1;
                    // index increment
                    index += 1;
                // display message
            return 0;
