Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
How to get ViewToWorldScale in Orthographic Camera ?
10 REPLIES 10
Message 1 of 11
glib.vedmedenkoTNJYP
660 Views, 10 Replies
I'm using the BimTrack API to create a ViewPoint and the API request requires a ViewToWorldScale value for my Orthogonal camera. I can't find it in my Viewpoint in Navis nor in the JSON of my Viewpoint camera. How can I get this value?
Best regards!
10 REPLIES 10
Message 2 of 11
Hi @glib.vedmedenkoTNJYP ,
I have asked the Navisworks Engineering team for you.
I will keep you posted.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 11
The Navisworks Engineering team said they don't know what "ViewToWorldScale" means. It looks like that's not something they recognize.
Could you please explain what you mean by "ViewToWorldScale"?
Naveen Kumar T
Message 4 of 11
Hi @naveen.kumar.t
Thanks for your reply. Here you will find an image explaining what I am looking for.
Best regards !
Message 5 of 11
I do not now if API has such scale, or it is always a fix value, or some formula to calculate.
I checked with the Engineering team and I received the below comment from the Engineering team
"No. You'd have to work it out yourself"
Sorry I have no clue how to get this value.
Naveen Kumar T
Message 6 of 11
Just happen to see this thread,
Regarding the `ViewToWorldScale` (i.e. Orthographic Height), I think it should be the camera's `HeightField` in Navisworks COM API, according to the Navisworks COM API documentation.
Cheers,
Eason Kang
Developer Advocate
Developer Advocacy & Support Service
Autodesk Platform Service (formerly Forge)
Message 7 of 11
Hi, does anyone managed to find a solution for this?
Message 8 of 11
Description of HeightField.
For an orthographic camera, this is the distance between top and bottom planes of the camera view frustum. Default 0.785398 (45 degrees)
Message 9 of 11
Edit: After testing this answer is incorrect
Howdy, I believe they are referring to the units of the Navisworks document, which can be found:
Autodesk.Navisworks.Api.Application.ActiveDocument.units
here is a switch statement to return the value you are looking for-
                case Units.Meters:
                    docUnitScaleFactor = 1.0;
                    break;
                case Units.Centimeters:
                    docUnitScaleFactor = 100.0;
                    break;
                case Units.Millimeters:
                    docUnitScaleFactor = 1000.0;
                    break;
                case Units.Feet:
                    docUnitScaleFactor = 3.28084;
                    break;
                case Units.Inches:
                    docUnitScaleFactor = 39.3701;
                    break;
                case Units.Yards:
                    docUnitScaleFactor = 1.09361;
                    break;
                case Units.Kilometers:
                    docUnitScaleFactor = 0.001;
                    break;
                case Units.Miles:
                    docUnitScaleFactor = 0.000621371;
                    break;
                case Units.Micrometers:
                    docUnitScaleFactor = 1000000.0;
                    break;
                case Units.Mils:
                    docUnitScaleFactor = 39370.0787;
                    break;
                default:
                    break;
Message 10 of 11
Just to give some tips about the last comment, you can use Autodesk.Navisworks.Api.UnitConversion.ScaleFactor(Unit from, Unit to) to get thoses numbers
Message 11 of 11
I had to use the screenToWorld factor for my project, here is the method I used
double? ScreenToWorldFactor(View view, Point3D point)
  Viewpoint viewpoint = view.CreateViewpointCopy();
  if (viewpoint.Projection == ViewpointProjection.Perspective)
    if (!viewpoint.HasFocalDistance) return null;
    return viewpoint.Position.DistanceTo(point) * (viewpoint.VerticalExtentAtFocalDistance / viewpoint.FocalDistance) / view.Height;
  if (viewpoint.Projection == ViewpointProjection.Orthographic)
    return viewpoint.HeightField / view.Height;
  return null;
This convert any distance in pixel to world. You need to give a Point3D when the projection is perspective.
Use it like this :
double distanceInWorld = distanceInPixel * ScreenToWorldFactor(point).Value;
Hope it helps 🙂
Rail Community
