How to change the ribbon tab displayname
Message 1 of 16
Hi All,
I have created a plugin for Navisworks, however, I couldn't change the Ribbon Tab display name, here is my code:
<AddInPlugin(AddInLocation.AddIn,
CanToggle:=True,
LoadForCanExecute:=True,
CallCanExecute:=CallCanExecute.Always,
Icon:="Resources\\icon",
LargeIcon:="Resources\\logo",
Shortcut:="Ctrl+Shift+O",
ShortcutWindowTypes:="")>
<PluginAttribute("navs.ltf_pw_nw_open__",
"LTFD",
ToolTip:="Open a document ",
DisplayName:="Open")>
Public Class ltf_nw_open__
Inherits AddInPlugin
Public Overrides Function Execute(ByVal ParamArray parameters As String()) As Integer
End Function
End Class
and here is the title bar
Thank you.
Replies (15)
Message 2 of 16
Message 3 of 16
thank you Jhjang,
I'm using windows form.
Message 4 of 16
Hello @Anonymous!
I'm having the same struggle as you, how did you end up solving this issue? The blog posted above did not help me because for it to work the class needs to inherit from CommandHandlerPlugin.
JMGP
Message 5 of 16
hi,
Here is the code on my class
 <PluginAttribute("doxenter_commands__", "DOCX", ToolTip:="DoXenter", DisplayName:="DoXenter")>
    <RibbonLayoutAttribute("doxenter_ribbon.xaml")>
    <RibbonTabAttribute("ID_Tab_1")>
    <CommandAttribute("PW_OPEN_DOCUMENT__",
                      DisplayName:="    Open    ",
                      ToolTip:="Open document from ProjectWISE",
                      CanToggle:=True,
Public Class CustomRibbonCommandHandler Inherits CommandHandlerPlugin
....your code....
Now, in the plugins folder, which stays normally in
C:\Program Files\Autodesk\Navisworks Manage 2017\Plugins\
Add your plugin folder and add the following folder:
1 - En-Us (or whatever resource folder you are using)
2 - images
3 - And your dll  file
Hope it helps 🙂
Message 6 of 16
Thank you @Anonymous
I have something VERY similar to you, but the difference is that I inherit my class from AddInPlugin instead of CommandHandlerPlugin and I can't change that because of some functionalities that are specific for AddIn. I saw that your first post was inheriting from AddInPlugin. Do you know something about customizing limitations regarding the inheritance?
JMGP
Message 7 of 16
I think the trick is to put copy the resource folder  + images + dll file in the same folder under the plugin folder
 for my case, if I delete any of these files, it won't work.
2 - Try to give access to everyone to the folder
Message 8 of 16
Hello again @Anonymous
Tried and didnt work. I'll provide the relevant part of the code with the output to see if you see any anomalies.
CS File:
[Plugin("Timeliner.DumpTimelinerTasks", // Plugin name
"ADSK", // Developer ID or GUID
ToolTip = "DIPDIPDULIDU", // The tooltip for the item in the ribbon
DisplayName = "HELLO")] // Display name for the Plugin in the Ribbon
[Strings("ADNRibbonDemo.name")]
[RibbonLayout("ADNRibbonDemo.xaml")]
[RibbonTab("ID_CustomTab_1", DisplayName = "HELLO")]
[Command("ID_Button_1", Icon = "uno.ico", LargeIcon = "dos.ico", ToolTip = "Show a message")]
public class DumpTimelinerTasks : AddInPlugin
XAML File:
<RibbonControl
x:Uid="ADNRibbonDemo" xmlns="clr-namespace:Autodesk.Windows;assembly=AdWindows"
xmlns:wpf="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:adwi="clr-namespace:Autodesk.Internal.Windows;assembly=AdWindows"
xmlns:system="clr-namespace:System;assembly=mscorlib"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:local="clr-namespace:Autodesk.Navisworks.Gui.Roamer.AIRLook;assembly=navisworks.gui.roamer">
<!-- END STANDARD SECTION DO NOT EDIT -->
<RibbonTab Id="ID_CustomTab_1" KeyTip="T1">
<RibbonPanel x:Uid="RibbonPane1_1">
<RibbonPanelSource x:Uid="RibbonPanelSource_RibbonPanel_1" KeyTip="C1" Title="Large Button">
<local:NWRibbonButton x:Uid="Button_1" Id="ID_Button_1"
Size="Large"
KeyTip="B1"
ShowText="True"
Text="Button 1 in xaml"
Orientation="Vertical"/>
</RibbonPanelSource>
</RibbonPanel>
</RibbonTab>
</RibbonControl>
Output:
So neither the "Tools add-ins 1" and the picture/logo changed.
Any ideas?
Message 9 of 16
Ning_Zhou
Navisworks 2019, how to change default name "Tool add-ins 1", really no solution at all?
Message 10 of 16
Message 11 of 16
Hugo.Bergeron
I also tried building the demo provided by xiaodong-liang and Tab wont appear in the Navisworks ribbon.
I can create a plugin that shows up in the "Tools add-ins 1" (nice name), I just cant create a simple Tab in the Ribbon with a single button that runs a command...
Anyone has a working demo?
Please dont link to https://adndevblog.typepad.com/aec/2012/07/custom-ribbon-of-navisworks-part-1.html as even the source code builds but wont do anything in Navisworks.
Love how Autodesk breaks plugin between releases too... Talk about backward compatibility.
Message 12 of 16
ulski1
I don't have a sample project for you but I can say that naming custom tabs works fine in Navisworks 2021 in my code
Message 13 of 16
Hugo.Bergeron
Thanks, can you specify the differences between the Autodesk demo (from 2012) and your code?
Message 14 of 16
ulski1
That I don’t recall but a common mistake is forgetting to copy the extra files such as resource files into the plug-in folder
Message 15 of 16
Hugo.Bergeron
Yeah but no, xaml and .txt (or .name) files set to always copy
Message 16 of 16
swarali_kulkarni4KMYK
How we can create a .xaml file? is it a WPF  or Windows form .xaml file?
I am confused if we inherited the class from the AddInPlugin class rather than the CommandHandlerPlugin,  is it not possible to change the display name of the plugin?
