Excel hyperlink to comment tag viewpoint
viswan_sajit
viswan_sajit
This is something used by several Navisworks users to capture follow up points coming off a 3D model review. The traditional method is to use an excel listing. Copy paste a .jpeg screen image of the view in a before and after sequence. Agree that this is crude. This is what I am trying to improve upon by making use of a hyperlink reference to a tag. Incidentally model review comments are based on view points tags. However automation ends there and the rest is merely a flat excel listing and image copy pasting.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @viswan_sajit ,
Your description of the issue is unclear and difficult to understand.
Please provide a detailed explanation using the following format, with a clear and concise response, so I can better understand your problem and assist you effectively.
  1. A short and precise description of what you are trying to achieve.
  2. Describe the observed behavior compared to your expected outcome, and explain why this is a problem.
  3. Include a complete yet minimal Navisworks sample model for testing the issue.
  4. Provide a complete yet minimal Visual Studio solution that can be compiled, loaded, run, and debugged with a single click to analyze its behavior in the sample model.
  5. Include detailed, step-by-step instructions for reproducing the issue, such as which element to select and what command to execute.
  6. Attach screenshots or a brief video demonstrating the issue.
Note:
  • Do not send any information that you consider to be a trade secret of your company.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
viswan_sajit
This is not any issue. I am seeking a solution to a task. You would have understood if you have used Navisworks to view a 3D model. I think it will be better if we can connect over Teams.
Sajit
viswan_sajit
Hello Naveen, will it be possible to connect on a Teams meeting? I can quickly explain you.
