Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Embedded links with ActiveX
5 REPLIES 5
bbrown
642 Views, 5 Replies
Is it possible to display or reference document links embedded on objects in the ActiveX control?
5 REPLIES 5
xiaodong_liang
in reply to: bbrown
Are you referring to the attributes of the objects? If yes, built-in COM control supports to access the attribute. Before 2012, the control is called dynamic control. From 2012, it is called Integrated control.
<Navisworks Installation path>\api\COM\examples\AUTO_06 is a sample. Although it is an Automation application, you could also use it with control.
Xiaodong Liang
Developer Technical Services
bbrown
in reply to: xiaodong_liang
I apologize, I meant to say with the redistributable API, not the integrated.
xiaodong_liang
in reply to: bbrown
Sorry, redistributable control has limited abilities. You cannot access attribute with it.
bbrown
I discovered that if you set State.URLsEnabled = true you can display embedded links with the redistributable ActiveX control.
xiaodong_liang
in reply to: bbrown
sorry, I thought you need to access the attribute attached to the object and mixed with your another question. Yes, as you have seen, displaying URL is supported, Same to smart tag. if you encounter the error 'unlicensed api', that means this API does not supported.
Rail Community
