Customizing item contextual drop down menu
alexisDVJML
alexisDVJML
Is is possible to programmatically add items to this contextual menu:
Even if only at the end, this would be EXTREMELY useful 😉
Thanks for any tips.
Main Scientist, Full Stack Developer & When Time Permits Director of IDIGO ► On your marks, Set, Go
geethat
[PluginAttribute("HelloWorld_ContextMenu",//Plugin name
"ADSK",//Developer ID or GUID
//The tooltip for the item in the ribbon
ToolTip = "Hello World Plugin in AddIn Tab in Context Menu",
//Display name for the Plugin in the Ribbon
DisplayName = "HelloWorld ContextMenu")]
[AddInPlugin(AddInLocation.CurrentSelectionContextMenu)]
public class HelloWorldContextMenu : AddInPlugin
public override int Execute(params string[] parameters)
MessageBox.Show("Hello World");
//Can do whatever required.
return 0;
I hope this helps.
alexisDVJML
Magnificent,
Many Thanks @geethat. Time to play with AddInPlugin CanExecute CommandState content 😀
Important Note: this works only for the main window, not for the Saved ViewPoints, which is what I wanted 😢, but great help anyway 👌
Here in main pane, my command is there, yeah:
Here in Saved ViewPoints pane, my extra command is missing 😶:
Thanks again @geethat .
eduardo_salvador02
Hello, how were you able to access the menu and create a custom option? I'm having the same problem.
Do you have any example code?
eduardo_salvador02
Ignore the message above, I got it LOL
