CurrentViewpoint.Position doesnt equal Position Readout in HUD
jhdempsey
jhdempsey
Hi All
Im trying to get the camera position of the current viewport (i.e. the coordinates given by the position readout in the Heads Up Display or HUD)
I have followed the solution in the below post, but the coordinates i get from the oDoc.CurrentViewpoint.Value.Position attribute are very different to whats shown in the position readout.
https://forums.autodesk.com/t5/navisworks-api/export-position-readout-coordinates-from-nwd-file-as-c...
In the screenshot below from my model, you can see the position readout X value is 491719.128, but the position X attribute through the API is 1613251.733
Can anyone explain why its different, and how to get he values shown on the position readout?
alexisDVJML
Just my guess: you should use document Units to convert the values.
Taking your example "491719.128, but the position X attribute through the API is 1613251.733":
1613251.733 / 491719.128 = 3.28
1 feet = 305mm, 1m = 1,000mm => ratio m/ft = 3.28 😀
Main Scientist, Full Stack Developer & When Time Permits Director of IDIGO ► On your marks, Set, Go
ulski1
I have done this by calculating a scale factor - here is how I convert from model units to Meters
double MyScaleFactor = Autodesk.Navisworks.Api.Interop.LcOaUnit.ScaleFactor(Autodesk.Navisworks.Api.Units.Meters, Autodesk.Navisworks.Api.Application.ActiveDocument.Units);
there is properly a simpler way
br
Ulrik
alexisDVJML
I personally have all these conversion ratios in static tables and I cache it for the current document in my plugin using various events to update it where necessary.
BTW, this settled your issue, am I correct? Thus can mark it as solution ?
Your Sincerely.
