Create a menu tooltip on click in items in Selection Tree
eduardo_salvador02
eduardo_salvador02
Hello!
I would like to know if it is possible to access the SelectionTree through the Navisworks .NET API, and thus be able to create a tooltip menu when selecting an item in the tree.
If anyone has an example of how to access, or if it is possible to access or create something, I would be grateful.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @eduardo_salvador02 ,
It appears that you have found a solution from this below forum post.
https://forums.autodesk.com/t5/navisworks-api/customizing-item-contextual-drop-down-menu/td-p/118710...
Did it solve your issue?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
eduardo_salvador02
Yes, that solved my problem, thank you very much!
