Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Center text and click events in RenderPlugin
4 REPLIES 4
igor.barcelosC54YD
187 Views, 4 Replies
Following this post https://forums.autodesk.com/t5/navisworks-api/create-tags-redlines-in-the-api/m-p/12694487#M7485 I could integrate some MarkUps in my view using the RenderPlugin as shown below :
I have two more questions :
1/ How can I center the text inside the markup's circle ? I imagine that I would need some function to measure the text in order to properly calculate the coordinates.
2/ How can I create click events in those markups ?
Thank you all for your attention.
4 REPLIES 4
1/ Use graphics.Text2DExtends to measure the box of your text, then use half the witdh and height to center it.
2/ Create an InputPlugin, inside MouseDown event check if the mouse (x and y) is over one of your markup.
Good luck
Hi, thanks a lot for your return.
I could manage to center my text using the TextExtents2D tool like below :
I will try to implement the click events in the following days.
Quick suggestion.
If you draw thousands of these, computing Text extends in the rendering loop (and also creating new TextFontInfo) is very CPU intensive.
I recommend to:
- compute the text extend once and store the value with the text itself (in an array of struct for exemple)
- for the TextFontInfo, if you use the same for all texts, just create it once and store it in your Renderer
Main Scientist, Full Stack Developer & When Time Permits Director of IDIGO ► On your marks, Set, Go
Nice btw!
Rail Community
