Autodesk.Navisworks.Api package not found
tom_huguet
tom_huguet
Hello everyone,
I can't find the necessary packages to be able to create my first navisworks 2023 plugin.
In addition, I'm on Visual Studio Code.
Thank you in advance for your response.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @tom_huguet ,
The minimum system requirements of Navisworks developers is Navisworks Simulate or Manage should be installed in the machine.
I have no clue whether VS code supports Navisworks Plugin development or not.I think you need to have Visual studio community.
Once Navisworks is installed in the machine, you can get the required dlls from the Navisworks.
Please take a look at this below link
https://apidocs.co/apps/navisworks/2018/87317537-2911-4c08-b492-6496c82b3ed0.htm
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
tom_huguet
Thank you very much but how am I supposed to know which dlls I should take ?
naveen.kumar.t
Autodesk Support
Autodesk Support
You will need "Autodesk.Navisworks.Api.dll"
Please take a look at these below links
https://www.autodesk.com/autodesk-university/class/Make-NavisWORK-You-Intro-Navisworks-API-2018#pres...
https://apidocs.co/apps/navisworks/2018/87317537-2911-4c08-b492-6496c82b3ed6.htm
Naveen Kumar T
