Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Auto-Popup Plugin Window with Navisworks Construction Simulation Start
3 REPLIES 3
197 Views, 3 Replies
Currently, I have created a plugin window. How can I make it automatically pop up when the construction simulation in Navisworks begins?
3 REPLIES 3
naveen.kumar.t
in reply to: 2139059197
Hi @2139059197 ,
I communicated with the Navisworks Engineering team to get answers for you.
Unless you can see something documented, I don't think we have any events for the start of a Timeliner simulation.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
in reply to: naveen.kumar.t
hi @naveen.kumar.t,
Thank you very much for your reply!
Can Navisworks be further developed in the 4D dimension, such as using Timeliner to implement some plugin functions? I have developed some plugins, but they can only run in the 3D dimension. I hope to implement these plugin functions during construction simulation. What should I do? It would be even better if there are some reference examples.
naveen.kumar.t
Rail Community
