ActiveX Viewpoint Folder Structure
bbrown
bbrown
I have been able to extract with VBScript all the viewpoints from a NWD model like the example shows, but I'm wondering if the folder structure can be referenced the same way. I would like to group my saved viewpoints by folder on the webpage.
xiaodong_liang
Autodesk Support
Autodesk Support
Do you want to access the folder and the view points within it? If yes, following is some small code.
Private Sub recurseFolderView(view As InwOpFolderView)
   Dim eachView As InwOpSavedView
   Dim oFolderView As InwOpFolderView
   For Each eachView In view.SavedViews
      If eachView.Type = eSavedViewType_Folder Then
         Debug.Print eachView.Name & "is a folder"
         Set oFolderView = eachView
         recurseFolderView oFolderView
      Else
          MsgBox "next view  " & eachView.Name
         m_state.ApplyView eachView
   Next
End Sub
Private Sub ApplyViewWithEachSavedView()
Dim savedview As InwOpSavedView
For Each savedview In m_state.SavedViews
  If savedview.Type = eSavedViewType_Folder Then
     Set oFolderView = savedview
  Else
       MsgBox "next view  " & savedview.Name
      m_state.ApplyView savedview
Next
Xiaodong Liang
Developer Technical Services
bbrown
I am using VBScript and the redistributable API inside a webpage for this project and I'm having difficulty referencing the nested views to change them programmatically. The InwOPSavedView.nwID property gives me a permission denied error, so I am unsure how to find a particular view once I've wrote a list to my website. The only way I can think to find the view again is to loop back over the views and match them by name, which will be problematic if there are two with the same name. Is there another way I'm not seeing?
bbrown
In an stateless environment like a browser, how am I supposed to find a SavedView again using the Unlicensed API? (Redistributable ActiveX control)
bbrown
Figured this one out. I had to build an array in VBScript of all the view objects and reference that array when my button was clicked.
