Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Acad Object Enabler for Navis Works 2023
2 REPLIES 2
gennadyKhkh
347 Views, 2 Replies
I have multiple object enablers (custom entities) for Acad 2022-2024. Which one is appropriate for Navis Works 2023?
Thank you
2 REPLIES 2
Hi @gennadyKhkh ,
Looks like not a Navisworks API issue to me.
This forum is dedicated to Navisworks API only.
Anyway, I found this below link
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Object-Enablers-fo...
It looks like, you need to use Object Enabler 2023 for Navisworks 2023
If you still have any question, please post the issue in Navisworks Product Forum
Navisworks Product Forum: https://forums.autodesk.com/t5/navisworks-forum/bd-p/372
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thank you, Kumar, for help.
Yes, it was not api issue but Navisworks Manage itself, just started diving into sdk samples. Toggling check box in NWManage Options/FileReaders/DWG/ConvertObjectProperties fixed the problem.
Best regards,
Gennady
Rail Community
