Simulate 2022 gives error loading Navisworks.Api.Controls
DeanLyon2
Message 1 of 8
DeanLyon2
I am rewriting an application for use with Simulate 2022. It compiles and works against 2019.  I have updated my references to point at the 2022 versions of the DLLs (assemblies). However, I am getting an error when I run the program when it hits this line:
Autodesk.Navisworks.Api.Controls.ApplicationControl.ApplicationType = ApplicationType.SingleDocument;
The error says System.IO.FileNotFoundException: can not load file or assembly Autodesk.Navisworks.Api.dll or one of its dependencies. I have tried .Net 4.7, 4.7..1, 4.7.2, and 4.8.  This is a console application that combines DWG files into a Navisworks model.  Just trying to make it work with Simulate 2022.
Replies (7)
Message 2 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @DeanLyon2 ,
Maybe you can try by changing the "Copy Local" value of Navisworks dlls.
If the above suggestion doesn't help, then, Could you please send us a simple non-confidential reproducible visual studio project and a step-by-step approach to reproduce the issue?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
DeanLyon2
All of the Autodesk references are set to True for Copy Local. I have attached an example that produces the same error. I do have this code in another module than Main but it produces the same error when run from Main.
Message 4 of 8
DeanLyon2
I have installed Visual Studio 2022 and it gives the same errors.
Message 5 of 8
DeanLyon2
If I set the .NET to lower than 4.7. I do get the error that Navisworks.Api.Controls needs .NET 4.7  When I compile and run at 4.7 I get the error that Navisworks.Api.Controls can not run.
Message 6 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @DeanLyon2 ,
Sorry for the delay.
I tested your application. I have no clue what is causing the issue in your application.
I created my own console application and copy-pasted the sample code which is present in your application. My console application is working fine.
I would suggest you create a new project and test it.
Here are the steps I followed
1)I created a console application.
2)I added the required dlls to my console visual studio project(NW Simulate 2022).
3)I set "Autodesk.Navisworks.Resolver" copy the local value to "True".For other dlls, I set copy the local value to "False"
4) Right-click your project in solution explorer--> Properties --> Build -->Platform target-->Set "x64"
5)Now everything worked fine for me.
Here is the sample code I used
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using Autodesk.Navisworks.Api;
using Autodesk.Navisworks.Api.ApplicationParts;
using Autodesk.Navisworks.Api.Controls;
using Autodesk.Navisworks.Api.DocumentParts;
using Autodesk.Navisworks.Api.Plugins;
using Autodesk.Navisworks.Api.Resolver;
using Autodesk.Navisworks.Api.Data;
namespace Simple_Console
    class Program
        [STAThread]
        static void Main(string[] args)
            //BuildModel cmb = new BuildModel();
            String runtimeName = Resolver.TryBindToRuntime(RuntimeNames.NavisworksSimulate);
            if (String.IsNullOrEmpty(runtimeName)) { throw new Exception("Failed to bind to Navisworks runtime"); }
            //cmb.BuildCompositeModel(PlantCode, RemoveList, IncludeList);
            //cmb = null;
            try
                XMain(args);
            catch (Exception exp)
                MessageBox.Show(exp.Message);
        private static void XMain(string[] args)
            List<Model> ModelList = new List<Model>();
            Autodesk.Navisworks.Api.Automation.NavisworksApplication oApp = null;
            Autodesk.Navisworks.Api.Application.FileInteractiveResolving += Application_FileInteractiveResolving;
            Autodesk.Navisworks.Api.Application.FileResolving += Application_FileResolving;
            ApplicationControl.Initialize();
            DocumentControl documentCtrl = new DocumentControl();
            documentCtrl.SetAsMainDocument();
            Console.WriteLine("End");
            Console.ReadKey();
        private static void Application_FileResolving(object sender, FileResolvingEventArgs e)
            e.Handled = true;
        private static void Application_FileInteractiveResolving(object sender, FileInteractiveResolvingEventArgs e)
            e.Handled = true;
Naveen Kumar T
Message 7 of 8
DeanLyon2
.NET 4.7 is correct. Copy Local is True on Resolver and False on the other Navisworks references.  These settings made the issue go away.  Thank you so much. I was banging my head against a wall on this one.
Message 8 of 8
gustavo_sanches7ZZVWX
Observer
Observer
hi! I am having the same trouble, i followed everything it was discussed here. But nothing was solved. Does anyone has any other suggetion what could it be?
