Set Selection Resolution
xaotix
xaotix
Is there a way to alter the resolution programmatically?
  • File, Layer, First Object, Last Object, Last Unique, Geometry.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @xaotix ,
Please try using the below code
 using (LcUOptionLock optionLock = new LcUOptionLock())
     // Get the root options using the lock
     LcUOptionSet rootOptions = LcUOption.GetRoot(optionLock);
     // Retrieve the pointer to the specific option by name
     LcUNameRefPtr optionPointer = rootOptions.GetName("interface.selection.resolution");
     // Check if the pointer exists before attempting to set the value
     if (optionPointer != null)
          * Selection Resolution Options:
          *  0 = File
          *  1 = Layer
          *  2 = First Object
          *  3 = Last Unique
          *  4 = Last Object
          *  5 = Geometry
         // Update the selection resolution option to "Geometry" (value 5)
         string resolutionValue = "RoamerGUI_PickResolution:5";
         rootOptions.SetName("interface.selection.resolution", new NamedConstant(resolutionValue));
         LcOpRegistry.SaveGlobalOptions();
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
ulski1
For Navisworks Simulate 2024 you can write some code which modifies this registry key:
HKEY_CURRENT_USER\SOFTWARE\Autodesk\Navisworks Simulate\21.0\GlobalOptions\interface\selection
the default value is:
Data: 8 26:RoamerGUI_PickResolution:4Last Object
Note that for Navisworks 2024 you alter version 210.0 since Navisworks 2024 is Navisworks version 21
Br
Ulrik
alexisDVJML
An old post of mine, with all Navisworks Global Settings at the time (Navisworks 2020) and how to read/change them:
Accessing & Modifying Navisworks Global Settings
Main Scientist, Full Stack Developer & When Time Permits Director of IDIGO ► On your marks, Set, Go
xaotix
thank you guys!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @imustafa_adel,
You asked me how to read the value of 'Selection Resolution' (by contacting me via chat message).
Here is the answer.
     LcUNameRefPtr s=rootOptions.GetName("interface.selection.resolution");
     MessageBox.Show(s.GetPtr().ToString());
I'm posting it here so that others with similar questions can also refer to this thread and find the answer.
Naveen Kumar T
imustafa_adel
Thank you I've also refined the method a little bit as shown below:
public static void SetSelectionResolution(SelectionResolution selectionResolution)
          var commandstr = "interface.selection.resolution";
                  LcUNameRefPtr optionPointer = rootOptions.GetName(commandstr);
                          string resolutionValue = "RoamerGUI_PickResolution:2";
                          switch (selectionResolution)
                                  case SelectionResolution.File:
                                          resolutionValue = "RoamerGUI_PickResolution:0";
                                          break;
                                  case SelectionResolution.Layer:
                                          resolutionValue = "RoamerGUI_PickResolution:1";
                                          break;
                                  case SelectionResolution.FirstObject:
                                          break;
                                  case SelectionResolution.LastUnique:
                                          resolutionValue = "RoamerGUI_PickResolution:3";
                                          break;
                                  case SelectionResolution.LastObject:
                                          resolutionValue = "RoamerGUI_PickResolution:4";
                                          break;
                                  case SelectionResolution.Geometry:
                                          break;
                          rootOptions.SetName(commandstr, new NamedConstant(resolutionValue));
public static SelectionResolution GetSelectionResolution()
          var res = string.Empty;
                  var data = new VariantData();
                  var result = rootOptions.GetDataValue(commandstr, data);
                  if (result) res = data.ToNamedConstant().Name;
          switch (res)
                  case "RoamerGUI_PickResolution:0":
                          return SelectionResolution.File;
                  case "RoamerGUI_PickResolution:1":
                          return SelectionResolution.Layer;
                  case "RoamerGUI_PickResolution:2":
                          return SelectionResolution.FirstObject;
                  case "RoamerGUI_PickResolution:3":
                          return SelectionResolution.LastUnique;
                  case "RoamerGUI_PickResolution:4":
                          return SelectionResolution.LastObject;
                  case "RoamerGUI_PickResolution:5":
                          return SelectionResolution.Geometry;
                  default:
public enum SelectionResolution
          File,
          Layer,
          FirstObject,
          LastUnique,
          LastObject,
          Geometry
