Selection set creation from outside Navisworks....
Murali_Kandasamy
Murali_Kandasamy
I want to create selection sets from outside Navisworks.... I have list of Components OIDs, using that needs to create selectionsets, I already having program for creating Searchset, this request is for "Selectionsets"
Murali. K
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Murali_Kandasamy ,
Try using this below sample code
 Document doc = Autodesk.Navisworks.Api.Application.ActiveDocument;
            DocumentSelectionSets oSets = doc.SelectionSets;
            Search s = new Search();
            SearchCondition sc = SearchCondition.HasPropertyByDisplayName("Item", "Name");
            s.SearchConditions.Add(sc.EqualValue(VariantData.FromDisplayString("ROOF_3")));
            s.Selection.SelectAll();
            s.Locations = SearchLocations.DescendantsAndSelf;
            ModelItemCollection from = s.FindAll(doc, false);
            doc.CurrentSelection.Clear();
            doc.CurrentSelection.CopyFrom(from);
            SavedItem newItem = new SelectionSet(doc.CurrentSelection.SelectedItems);
            newItem.DisplayName ="SelectionSetName";
            Autodesk.Navisworks.Api.Application.ActiveDocument.SelectionSets.InsertCopy(0, newItem);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Murali_Kandasamy
Thanks Mr. Naveen, let me check and update you...
