Sectioning in Navisworks Manage 2024 API not Available
andrea_alpiniYNYBC
andrea_alpiniYNYBC
is it possible to create Sectioning box (similar to GUI) by C# Code PlugIn?
tetsuya_miwa
Autodesk.Navisworks.Api.Application.ActiveDocument.ActiveView.SetClippingPlanes
Apply section box by GUI and you can see string of Json by  GetClippingPlanes.
andrea_alpiniYNYBC
it Works!! thank you for suggestion,
public static void ApplyNavisworksClipping(double cloudX, double cloudY, double cloudZ, double cloudXLen, double cloudYLen, double cloudZLen)
try
// Use culture-invariant formatting to ensure decimal points are always periods
System.Globalization.CultureInfo invariantCulture = System.Globalization.CultureInfo.InvariantCulture;
// Calculate the box corners
double minX = cloudX - cloudXLen / 2;
double minY = cloudY - cloudYLen / 2;
double minZ = cloudZ - cloudZLen / 2;
double maxX = cloudX + cloudXLen / 2;
double maxY = cloudY + cloudYLen / 2;
double maxZ = cloudZ + cloudZLen / 2;
// Create JSON string for OrientedBox3D format
string jsonClipPlaneSet = $@"
""Type"": ""ClipPlaneSet"",
""Version"": 1,
""OrientedBox"": {{
""Type"": ""OrientedBox3D"",
""Version"": 1,
""Box"": [
[{minX.ToString(invariantCulture)}, {minY.ToString(invariantCulture)}, {minZ.ToString(invariantCulture)}],
[{maxX.ToString(invariantCulture)}, {maxY.ToString(invariantCulture)}, {maxZ.ToString(invariantCulture)}]
""Rotation"": [0, 0, 0]
""Enabled"": true
// Remove newlines and extra spaces for a more compact JSON
jsonClipPlaneSet = jsonClipPlaneSet.Replace("\r", "").Replace("\n", "").Replace(" ", "");
// Log coordinates for debugging
System.Diagnostics.Debug.WriteLine($"Center: ({cloudX}, {cloudY}, {cloudZ})");
System.Diagnostics.Debug.WriteLine($"Dimensions: ({cloudXLen}, {cloudYLen}, {cloudZLen})");
System.Diagnostics.Debug.WriteLine($"Box min: ({minX}, {minY}, {minZ})");
System.Diagnostics.Debug.WriteLine($"Box max: ({maxX}, {maxY}, {maxZ})");
// First try with TrySetClippingPlanes to avoid exceptions
bool success = Application.ActiveDocument.ActiveView.TrySetClippingPlanes(jsonClipPlaneSet);
if (!success)
System.Diagnostics.Debug.WriteLine("Failed to set clipping planes with TrySetClippingPlanes");
// Fall back to SetClippingPlanes which will throw an exception with more details if it fails
Application.ActiveDocument.ActiveView.SetClippingPlanes(jsonClipPlaneSet);
// Request a view update
Application.ActiveDocument.ActiveView.RequestDelayedRedraw(ViewRedrawRequests.All);
catch (Exception ex)
System.Diagnostics.Debug.WriteLine($"Error setting clipping planes: {ex.Message}");
// Uncomment for debugging in UI
// WF.MessageBox.Show($"Error setting clipping planes: {ex.Message}", "Error");
