Re: ActiveX control in Visual Studio
Thanks, now if I could not help with this problem I have, I am working with the controller , I have the application done, but when uploading to the intranet models do not recognize me, because are not in te same folder of the project, but when I run locally the mo0dels (functions) on the other hand found a similar.
Exameple on Navisworks driver but for .dwf this will create a folder on the server or something similar, but not how to solve this problem is not what I mean well. In any case I found annecede example to see if I can you help me thank you very much.
This is the example, shown in read is one of muy questions is what we want to know, as was donde on that folder so that you can get all models and can be viewed on any machine without needing to install software of autodesk.
<object classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF" codebase="http://www.autodesk.com/global/dwfviewer/installer/DwfViewerSetup.cab#version=6,0,0,200" id="Eview" width="800" height="600" border="2" bordercolor="red"><param name="src" value="http://www.autodesk.com/global/dwf/samples/better_markups_large.dwf"></param></object></td></tr></table>
</body></html>
