Passing array of objects to Plugin Execute() method instead of array of strings
HusseinOthman75
Message 1 of 8
HusseinOthman75
A very crucial thing when using Navisworks plugin through C# Application (in my case) is the parameters passed from application to the plugin through calling Execute() method which is array of strings. The array of strings represents a bottleneck which limit the power of using Navisworks. For example with array of strings i can pass only the name of items to be selected in navisworks, but with passing array of objects i can pass the name, status, priority, ..... etc. for each array item, which give much pawer manipulating navisworks items : for example i can select items by name where status="Done" or Priority=1 or ..... etc. Is this option available? if not could we raise this substencial issue to Navisworks development team. Regards
Replies (7)
Message 2 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @HusseinOthman75 ,
A string can be JSON that you deserialize to obtain the desired data.
If this doesn't help, please let me know.
I will submit an improvement ticket for this issue.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
HusseinOthman75
Hi Naveen,
Thank you for your answer. Can you please drive an example , passing data to plug in as Json,
Regards
Message 4 of 8
HusseinOthman75
Hi Naveen,
Regards
Message 5 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Please take a look at the attached files for the sample code. Here is the sample code to access an array of object data located in "Test" inside "Navisworks_2023"
Naveen Kumar T
Message 6 of 8
HusseinOthman75
Hi Naveen,
Thank you very much for your help, highly appreciated. i applied the logic in your example but i recieve the following error :
Note : This is a C# application. InvokeNavisworksPlugInTestPack1() method runs NavisworksApplication and Append
the the required model. then i invoke the plugin and pass the JSON string as shown. I tried to resolve this error
but to no avail.
Thanks agin for you help.
Message 7 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
I cannot replicate the issue on my end.
The attached sample code functions properly on my end.
Kindly refer to the attached files.
Naveen Kumar T
Message 8 of 8
HusseinOthman75
Hi naveen,
Thanks you for your technical support. The issue is resolved and your solution works perfectly
Regards
