Need Help-How to change Model Tree hierarchy of Navisworks ?
piyinghai
Observer Observer
piyinghai
Observer
Observer
I imported my files from Revit into Navisworks. The selected tree structure is fixed and cannot be changed.I try to change porperty.Value , But not modifiable.I need to render the selection tree of Navisworks based on the data I entered in Revit.
  I've seen someone implement choice tree structural refactoring as below:
 But I don't know how to do that.like below
Please help me. Best wish !
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @piyinghai ,
To the best of my knowledge, it is not possible to modify the Model Tree hierarchy in Navisworks. However, you can sort the existing Model Tree hierarchy or create a custom selection tree.
Please refer to the following links for more information:
https://adndevblog.typepad.com/aec/2013/04/use-navisworks-api-with-wpf-binding-model-hierarchy-to-tr...
https://forums.autodesk.com/t5/navisworks-api/sort-navisworks-model-tree-through-commandline/td-p/12...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
piyinghai
Observer
Observer
Thanks for your reply, I need to have a try. Before that, I would like to ask if the results achieved by this article are as follows, is it the result under the standard mode of Navisworks' selection tree?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @piyinghai ,
In your previous post, the attached image shows that I simply selected the standard mode and sorted the selection tree in ascending alphabetical order.
Naveen Kumar T
peter_hirn
Leaving this info here for future victims readers.
It's not possible to change the hierarchy directly. The best workaround I could find:
- Navisworks addin starts external process (ie. worker.exe) and establishes IPC (this is required as calling NwCreate directly from the addin is not possible, see https://adndevblog.typepad.com/aec/2012/05/nwcreate-with-net-plug-in.html)
- Addin reads structure, properties and raw geometry (vertices, normals, transforms) from model (see https://adndevblog.typepad.com/aec/2012/05/get-primitive-from-solid-of-navisworks.html)
- Addin transfers data via IPC to worker.exe
- worker.exe creates a Navisworks document from scratch using NwCreate and reassembles structure, geometry, properties
If you want to write your worker in C# you have to create your own bindings for `nwcreate.dll`, eg. https://gist.github.com/peterhirn/9c241386aecbf45de59256314c2a6372
OTOH the .NET COM interop performance is not great, so I'm now considering rewriting everything in C++, see https://adndevblog.typepad.com/aec/2018/09/get-primitive-from-solid-of-navisworks-by-native-com.html
