Navisworks Manage - starting automation and selecting ActiveDocument
Hi
very new to API's for Autodesk products. trying to automate a Navisworks session using vb.net  and get a document's information - model, layers etc.
code below works in starting the session and loading the file but I cant then select the active document - gets the error attached -= I am sure I am doing something stupid... but help would be appreciated, cant seam to find any vb.net examples all c.
thanks in anticipation
error attached as screen shot
Imports Autodesk.Navisworks.Api.Automation
Dim NWApp As New Autodesk.Navisworks.Api.Automation.NavisworksApplication
NWApp.OpenFile(Zone_File_Name.Text)
NWApp.Visible = True
Dim NWDOC As Autodesk.Navisworks.Api.Document
NWDOC = Autodesk.Navisworks.Api.Application.ActiveDocument
You cannot access the Navisworks application objects when running in automation mode, only call a plugin that does so using ExecuteAddInPlugin(pluginname).
So you need to encapsulate all your operations in a plugin, then execute your plugin from the automation app.
Hi
thanks, very helpful - I thought that might be the case.
ahmed.adel.hagag
hi @Anonymous  , could you share with me the project file ?
