Navisworks Manage 2023 crashes when adding plugin to the Plugins folder
16164BDZVH
16164BDZVH
I am trying to create a simple plugin using .NET 6.0 to add to the Navisworks Manage 2023.
Everything looks fine from the start to after I build the code.
I followed the instructions in the Navisworks University to create a Hello World program but every time I tried to run Navisworks the Autodesk Error Report appeared (where you put your email so they can send you the error report).
The instruction video that I followed: Make NavisWORK for You: Intro to the Navisworks API | Autodesk University
My C# code:
using wf = System.Windows.Forms;
using Autodesk.Navisworks.Api;
using Autodesk.Navisworks.Api.Plugins;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace HelloWorld
    [PluginAttribute("HelloWorld",
        //Plugin name
        "ADSK",
        //Character developer ID or GUID
        ToolTip = "Hello World",
        //The tool tip for the item in the ribbon
        DisplayName = "HelloWorld"
        //Display name for the plugin in the ribbon
    [AddInPlugin(AddInLocation.AddIn)]
    public class HelloWorld : AddInPlugin
        public override int Execute(params string[] parameters)
            wf.MessageBox.Show("Hello World");
            return 0;
Many thanks for any answers
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @16164BDZVH ,
I think you have chosen the .Net core instead of the .Net framework in Visual studio. That's why your Navisworks is crashing.
If this doesn't help, could you please explain your issue in detail?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
16164BDZVH
Thank you very much, my problem has been solved by your solution 🙂 Sorry for the late reply
