ModelItem.InstanceHashCode
How stable InstanceHashCode is? It seems that if open same file on different machine then it is changed.
Pauli
xiaodong_liang
Autodesk Support
Autodesk Support
From our engineer team:
InstanceHashCode is not really stable, it is just a hash code. It will only really be stable for the lifetime of the .NET object. You should only really use it for things such as inserting the object into a dictionary, etc…
The InstanceGuid is a better stable ID. Some files might not contain GUIDs though (it depends on the source of the file), although they might contain some other form of stable ID (such as Element ID or Entity Handle). And for some formats, it’s almost impossible to work out a stable ID in the first place.
Hope this helps.
