mmodification of xsl file to hide useless list for html clash report
Hello everybody,
I try to modify some part of my html clash report, specificly the long and useless list of the selection sets I made,  at the begining of the report. (see the "Gestion de conflit" file below.)
To clean that, I try to modify the xsl file named : "clashs_report_html.xsl", infortunedly even after erasing nearly everything in the xsl code, it still there... You can also find  below my last xsl code with nearly everything erase inside.
Is anyone know how I can fix it ?
Thanks in advance,
Guillaume.Chazal
Autodesk Support
Autodesk Support
Could you share a sample file with us so we could try to optimize the report generation to fits your needs.
Guillaume Chazal
Hello, Guillaume
Here you can find the latest xml file I done with nearly everything erase but still the list.. !
Thanks for your help !
https://transfernow.net/590s90j3qeev
Guillaume.Chazal
Autodesk Support
Autodesk Support
Thanks for the file you sent
I tried to run some clashes detections with Navisworks 2018 using different rules and selection  but the HTML reports I created didn’t include the selection sets definition.
Could you send me a Navisworks file with your clash settings already defined ?
In that case I would probably be able to reproduce the issue and then I’ll be able to try to edit the report templates to remove the unwanted part of the report.
Thanks again.
Guillaume Chazal
Hello Guillaume,
Here a navisworks file I had the issue with :
https://transfernow.net/01jks1r7ugcb
Maybe it's not relevant, but I work with the 2017 version of navisworks.
Thank you very much for your help !
Guillaume.Chazal
Autodesk Support
Autodesk Support
Sorry for the delay in replying your question.
I think that the easiest way to achieve that (removing the selection set definition from the report) would be to edit the html file after its generation.
You’ll find attached a picture that shows what should be removed from the html file after editing it with a text editor.
After that you’ll end up with a report without the selection set definition.
Guillaume Chazal
Thanks for helping me,
I already knew how to edit html file to delete the set defintion list in the report, but thanks for people that don't know ! 🙂
I was wondering that a more optimised solution could be find, but it's apparently to complicated and time-consuming ^^
Thanks anyway,
Have a good day !
