Invoking a plugin through automation
The plugin(shown below) is running when i click the button in Add-ins tab of Navisworks application. But when I try to execute the plugin through automation its not working.
using System;
using System.Collections.Generic;
using System.Windows.Forms;
using System.Text;
//Add two new namespaces
using Autodesk.Navisworks.Api;
using Autodesk.Navisworks.Api.Plugins;
using Autodesk.Navisworks.Api.Interop;
using Autodesk.Navisworks.Api.Timeliner;
using Autodesk.Navisworks.Api.Interop.Timeliner;
namespace BasicPlugIn
                [PluginAttribute("BasicPlugIn.ABasicPlugin",                        //Plugin name
                  "ADSK",        //4 character Developer ID or GUID
                  ToolTip = "BasicPlugIn.ABasicPlugin tool tip",                    //The tooltip for the item in the ribbon
                  DisplayName = "Simulation Play Plugin")]                           //Display name for the Plugin in the Ribbon
      public class ABasicPlugin : AddInPlugin //Derives from AddInPlugin
                    public override int Execute(params string[] parameters)
                                LcTlSimulationHelper.Instance.Play();
                                return 0;
#endregion
I am trying to execute the above plugin using
string aString = "Hello";
Autodesk.Navisworks.Api.Automation.NavisworksApplication navisworksApplication =
                                             new Autodesk.Navisworks.Api.Automation.NavisworksApplication();
navisworksApplication.ExecuteAddInPlugin("BasicPlugIn.ABasicPlugin.ADSK",aString);
But this does not help execute the plugin and start the timeliner simulation.
xiaodong_liang
Autodesk Support
Autodesk Support
Did you mean if LcTlSimulationHelper.Instance.Play(); cannot work when calling from an automation, or any code (like pop out a message box in the plugin)? If it is for LcTlSimulationHelper, sorry as I having said, this is NOT a public API we support now. We cannot guarantee all of its behaviors.
Yes. LcTlSimulationHelper.Instance.Play() is not working when that plugin is called through automation. But it is working perfectly as a plugin in navisworks application.
xiaodong_liang
Autodesk Support
Autodesk Support
Since this is not a public (unsupported) API, things could go wrong.. Sorry for not much helping at this moment.
