Installation of 2021 plugin different from 2020, 2019 & 2018
shayne.kiekebosch
shayne.kiekebosch
We have a plugin that works for Navisworks 2020, 2019 & 2018. When we install the plugin it places the .bundle folder in C:\ProgramData\Autodesk\ApplicationPlugins. The .bundle folder has the correct heirarchy like this:
name.bundle
  • PackageContents.xml
  • Contents
    • v14
      • All relevant .dlls for 2018
    • v15
      • All relevant .dlls for 2019
    • v16
      • All relevant .dlls for 2020
All I do to get the relevant .dlls for each version is change the references to that versions .dlls. I get the .dlls from the installation location of that version of Navisworks, so all I did for version 2021 was reference the .dlls from the 2021 installation location. It builds as normal and once I place the .dlls into a newly created v17 folder it doesn't appear in Navisworks anymore. I also modify PackageContents.xml to include the new v17 (2021).
I assume I just need to increment the numbers for folders etc. like v17, SeriesMin="Nw18" and that they haven't changed the versioning system?
I also tried moving our built .dll to C:\Program Files\Autodesk\Navisworks Manage 2021\Plugins\name\name.dll but it still didn't appear.
I also installed a plugin from the Autodesk plugins that worked for 2021 but that plugin went to C:\Program Files\Autodesk\Navisworks Manage 2021\Plugins which is a bit different from where ours sits.
Potential relevant information:
  • Navisworks 2018, 2019, 2020 & 2021 (2021 key version)
  • Visual studio 2015
    • .NET Framework 4.7.1
    • Completely written in C#
  • Windows 10 64-bit v1909 OS-build 18363.778
  • Referenced .dlls
    • AdWindows
    • Autodesk.Navisworks.Api
    • Autodesk.Navisworks.ComApi
    • Autodesk.Navisworks.Interop.ComApi
    • navisworks.gui.roamer
Let me know if anyone needs any more information. Any help is greatly appreciated!
shayne.kiekebosch
Answering my own question in case anyone else runs into this.
I did the same thing for our Revit plugin but when I went to build the Revit plugin it complained about the .NET version. So I upgraded the version from 4.7.1 to 4.8, built it and it worked.
The Navisworks plugin built fine without any complaints, it just opened Navisworks without any error or anything. So I then upgraded the .NET version to 4.8 too and now it works!
It would have been nice to be notified that it needed the newer version or a pop-up/error in Navisworks stating the .NET version was too low or something.
alexisDVJML
Thanks for sharing the solution, that will save us a lot of headaches.
Since you have rebuilt your plugin for NW2021, did you notice any differences in terms of API (additions, changes, behaviour changes, performance) ?
Main Scientist, Full Stack Developer & When Time Permits Director of IDIGO ► On your marks, Set, Go
shayne.kiekebosch
Hi @alexisDVJML,
Our 2021 plugin works the same as it does for our earlier versioned plugins. I didn't really have a deeper look into any API changes sorry.
The core of our plugin involves checking for a specific item, moving and hiding items and then exporting as a FBX. Hope that helps!
marcus.dionne
Hey, thanks for sharing. I've updated the framework but unfortunately still don't see my plugin in Navisworks 2021. Which directory and file structure in required? Similar to 2020?
C:\Autodesk\Navisworks Manage 20xx\Plugins\pluginName\pluginName.dll
Or
