Import Hyperlinks in excel file to Navisworks
I have an excel file , one of its columns contains hyperlinks to PDF files. when I use datatools to link the excel file with my Navisworks model, I can see the pdf full file name, but it is not a hyperlink.
Is there a way to import hyperlinks from excel file to Navisworks and keep it still as hyperlink?
Thanks!
xiaodong_liang
Autodesk Support
Autodesk Support
if you would like to import the hyperlink and create them by API, you can refer to this blog. It shows how to create. As to read Excel column and find the corresponding objects, I believe it is not a difficulty to you.
http://adndevblog.typepad.com/aec/2012/05/create-hyperlinks-for-model-objects-using-net-api.html
But, what you wanted is to use UI abilities of DataTools, I have to suggest you post the question on product board, where the product expert would be able to share a comment if there is a setting of DataTools can bind hyperlinks of Excel to objects of Navisworks.
https://forums.autodesk.com/t5/navisworks-general-discussion/bd-p/372
Mr. Liang,
Thank you very much for the help! By useing the API method you suggested, I am able to create the hyperlink from excel file.
By the way, can I create more then 1 hyperlinks?
Richard
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Richard,
I think that blog has shown how to create several hyperlinks/labels on one object. Could you elaborate if it is not what you need?
Yes, you are right. By following the blog, I was able to create multiple hyperlinks.
Thanks a lot!
hello,
Will you be able to share the code with me?
thanks in advance.
VPO
Good Morning, I am interested in the code, I would want to import hyperlinks from excell to Naviswork, would you mind yo send me please?
