How to set the tolerance for existing Clash Tests
ratno123s
ratno123s
I am trying to Create/Update clash tests with the following code:
private ClashTest GetClashTest(string ClashtestName, double tolerance)
            DocumentClash documentClash = Autodesk.Navisworks.Api.Application.ActiveDocument.GetClash();
            ClashTest ct = documentClash.TestsData.Tests.Where(x => x.DisplayName == ClashtestName).FirstOrDefault() as ClashTest;
            if (ct == null)
                ct = new ClashTest();
                ct.Tolerance = tolerance;
                ct.TestType = ClashType;
                ct.DisplayName = ClashtestName;
                documentClash.TestsData.TestsAddCopy(ct);
            else
            return ct;
The code works in the If part where I am creating a new Clash Test, but it throws an exception in the Else part where I am trying to set the tolerance of the existing ClashTest ( ct.tolerance=tolerance).
The exception says that the clash test is unmodifiable.
Please help me in setting the tolerance of existing clash tests
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @ratno123s ,
For already existing clash test, please try using the below sample code
1. You need to create a copy of your clash test. Let's call it "ClashTestCopy"
2. Edit the parameters of "ClashTestCopy"
3. Use DocumentClashTests.TestsEditTestFromCopy()
Here is the sample code
DocumentClashTests clashTests = documentClash.TestsData;
ClashTest clashTest = clashTests.Tests.Where(c => c.DisplayName == "Test 1").First() as ClashTest;
if(clashTest!=null)
   ClashTest new_clashTest = clashTest.CreateCopy() as ClashTest;
   new_clashTest.Tolerance =Tolerance Value in Double;
   new_clashTest.TestType = ClashTestType.HardConservative;
   clashTests.TestsEditTestFromCopy(clashTest, new_clashTest);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
