how to get triangle vertices that match what is visible in Navisworks?
vishalghuge2500
vishalghuge2500
I’m writing a Navisworks .NET add-in and need triangle vertices in world coordinates for a selected ModelItem (wall/floor/duct/pipe). The goal is to run my own triangle intersection and host-face normal clustering, but my extracted triangles don’t always match the actual visible surface in Navisworks (triangles appear offset/tilted when reconstructed in Dynamo), which causes wrong intersection results.
I’m extracting triangles using COM
ComApiBridge.ToInwOaPath(ModelItem)
InwOaPath3.Fragments()
InwOaFragment3.GenerateSimplePrimitives(...)
callback InwSimplePrimitivesCB.Triangle(v1,v2,v3) and reading v.coord
applying frag.GetLocalToWorldMatrix() (InwLTransform3f3.Matrix) to get world coords
Is GenerateSimplePrimitives expected to return triangles that exactly match the visible geometry / clash geometry? If not, what is the recommended API/approach to obtain reliable triangle vertices that match Navisworks display (or the clash engine) for intersection tests?
Below is my code.
using Autodesk.Navisworks.Api;
using Autodesk.Navisworks.Api.ComApi;
using System;
using System.Collections.Generic;
using COMApi = Autodesk.Navisworks.Api.Interop.ComApi;
namespace Navisworks90degApprover.Utilities
    public static class ComTriangleExtractor
        public static bool TryGetWorldTrianglesMm(ModelItem item, out List<TriangleIntersection.Tri> triangles, out string error)
            triangles = new List<TriangleIntersection.Tri>();
            error = null;
            if (item == null) { error = "item=null"; return false; }
            if (!item.HasGeometry) { error = "item.HasGeometry=false"; return false; }
            try
                object pathAny = ComApiBridge.ToInwOaPath(item);
                COMApi.InwOaPath3 path = pathAny as COMApi.InwOaPath3;
                if (path == null)
                    error = "ComApiBridge.ToInwOaPath did not return InwOaPath3. Actual type: " +
                            (pathAny == null ? "(null)" : pathAny.GetType().FullName);
                    return false;
                var frags = path.Fragments();
                int fragCount = frags.Count; // 1-based COM collection
                // First pass: sample some triangles to infer whether vertex units are meters or mm
                var sample = new List<TriF>(64);
                for (int i = 1; i <= fragCount && sample.Count < 32; i++)
                    var frag = frags[i] as COMApi.InwOaFragment3;
                    if (frag == null) continue;
                    var mtx = (COMApi.InwLTransform3f3)(object)frag.GetLocalToWorldMatrix();
                    var arr = (Array)(object)mtx.Matrix;
                    float[] m = new float[16];
                    for (int k = 0; k < 16; k++)
                        m[k] = Convert.ToSingle(arr.GetValue(k + 1));
                    Mat4 mat = Mat4.FromNavisworksMatrixRaw(m);
                    var cbSample = new SimplePrimCb { Matrix = mat, ScaleToMm = 1.0f };
                    cbSample.Clear();
                    frag.GenerateSimplePrimitives(COMApi.nwEVertexProperty.eNORMAL, cbSample);
                    for (int t = 0; t < cbSample.Triangles.Count && sample.Count < 32; t++)
                        sample.Add(cbSample.Triangles[t]);
                if (sample.Count == 0)
                    error = "No sample triangles extracted (0).";
                    return false;
                float scaleToMm = InferScaleToMm(sample);
                // Second pass: full extraction with detected scaling
                SimplePrimCb cb = new SimplePrimCb { ScaleToMm = scaleToMm };
                for (int i = 1; i <= fragCount; i++)
                    cb.Matrix = mat;
                    cb.Clear();
                    frag.GenerateSimplePrimitives(COMApi.nwEVertexProperty.eNORMAL, cb);
                    foreach (var tri in cb.Triangles)
                        triangles.Add(new TriangleIntersection.Tri(
                            new TriangleIntersection.V3(tri.A.X, tri.A.Y, tri.A.Z),
                            new TriangleIntersection.V3(tri.B.X, tri.B.Y, tri.B.Z),
                            new TriangleIntersection.V3(tri.C.X, tri.C.Y, tri.C.Z)
                if (triangles.Count == 0)
                    error = "No triangles extracted (0).";
                    return false;
                return true;
            catch (Exception ex)
                error = ex.ToString();
                return false;
        private static float InferScaleToMm(List<TriF> tris)
            var edges = new List<float>(tris.Count * 3);
            foreach (var t in tris)
                edges.Add(Dist(t.A, t.B));
                edges.Add(Dist(t.B, t.C));
                edges.Add(Dist(t.C, t.A));
            edges.RemoveAll(e => float.IsNaN(e) || float.IsInfinity(e) || e <= 1e-9f);
            edges.Sort();
            float median = edges.Count == 0 ? 1.0f : edges[edges.Count / 2];
            // Heuristic: if edges look like meters (0.001..50), scale to mm (x1000).
            if (median > 0.0001f && median < 50.0f)
                return 1000.0f;
            return 1.0f;
        private static float Dist(V3f a, V3f b)
            float dx = a.X - b.X;
            float dy = a.Y - b.Y;
            float dz = a.Z - b.Z;
            return (float)Math.Sqrt(dx * dx + dy * dy + dz * dz);
        private struct V3f
            public float X, Y, Z;
            public V3f(float x, float y, float z) { X = x; Y = y; Z = z; }
        private struct Mat4
            public float M11, M12, M13, M14;
            public float M21, M22, M23, M24;
            public float M31, M32, M33, M34;
            public float M41, M42, M43, M44;
            // Raw matrix values from InwLTransform3f3.Matrix (SAFEARRAY, 1..16)
            public static Mat4 FromNavisworksMatrixRaw(float[] m16)
                Mat4 r = new Mat4();
                r.M11 = m16[0]; r.M12 = m16[1]; r.M13 = m16[2]; r.M14 = m16[3];
                r.M21 = m16[4]; r.M22 = m16[5]; r.M23 = m16[6]; r.M24 = m16[7];
                r.M31 = m16[8]; r.M32 = m16[9]; r.M33 = m16[10]; r.M34 = m16[11];
                r.M41 = m16[12]; r.M42 = m16[13]; r.M43 = m16[14]; r.M44 = m16[15];
                return r;
            // Transform vertices using the convention that seems to match in our environment.
            // (The key problem: unclear whether this convention is correct for all models.)
            public V3f Transform(V3f v, float scaleToMm)
                float x = (v.X * M11 + v.Y * M21 + v.Z * M31 + M41) * scaleToMm;
                float y = (v.X * M12 + v.Y * M22 + v.Z * M32 + M42) * scaleToMm;
                float z = (v.X * M13 + v.Y * M23 + v.Z * M33 + M43) * scaleToMm;
                return new V3f(x, y, z);
        private sealed class SimplePrimCb : COMApi.InwSimplePrimitivesCB
            public Mat4 Matrix;
            public float ScaleToMm = 1000.0f;
            public List<TriF> Triangles = new List<TriF>();
            public void Clear() { Triangles.Clear(); }
            public void Triangle(COMApi.InwSimpleVertex v1, COMApi.InwSimpleVertex v2, COMApi.InwSimpleVertex v3)
                V3f a = ReadVertexRaw(v1);
                V3f b = ReadVertexRaw(v2);
                V3f c = ReadVertexRaw(v3);
                a = Matrix.Transform(a, ScaleToMm);
                b = Matrix.Transform(b, ScaleToMm);
                c = Matrix.Transform(c, ScaleToMm);
                Triangles.Add(new TriF(a, b, c));
            public void Line(COMApi.InwSimpleVertex v1, COMApi.InwSimpleVertex v2) { }
            public void Point(COMApi.InwSimpleVertex v1) { }
            public void SnapPoint(COMApi.InwSimpleVertex v1) { }
            private static V3f ReadVertexRaw(COMApi.InwSimpleVertex v)
                Array arr = (Array)(object)v.coord;
                float x = Convert.ToSingle(arr.GetValue(1));
                float y = Convert.ToSingle(arr.GetValue(2));
                float z = Convert.ToSingle(arr.GetValue(3));
        private struct TriF
            public V3f A, B, C;
            public TriF(V3f a, V3f b, V3f c) { A = a; B = b; C = c; }
    // Your project’s triangle types; included here for completeness if forum readers ask:
    public static class TriangleIntersection
        public struct V3
            public double X, Y, Z;
            public V3(double x, double y, double z) { X = x; Y = y; Z = z; }
        public struct Tri
            public V3 A, B, C;
            public Tri(V3 a, V3 b, V3 c) { A = a; B = b; C = c; }
alexisDVJML
Not sure what each of your 2 pictures refers to and what differences you got, so I can just guess/suggest a few things that could explain any differences based on my past experience.
Hope this helps at least a bit.
Notes:
- the only issue I experienced as point 3/ below, UserOffset
- I didn't really look at your code in details so I can't comment on it
1/ Triangles Order
The Triangles are not necessary in "logical" order, not sure your algorithm rely on triangle order
2/ Level of details
Navisworks Options can be used to specify the level of geometry compression is applied.
I did a bit of test and hard to predict actual impact.
3/ UserOffset
Each fragment contains a UserOffset representing a translation.
Seldomly used and not sure if need to be applied after using the LocalToWorld matrix OR included in it
Main Scientist, Full Stack Developer & When Time Permits Director of IDIGO ► On your marks, Set, Go
