How to Add/Edit Status or Comment of Viewpoint through the API?
From GUI of Navisworks, right-click the desired viewpoint in the Saved Viewpoints window, and click Add Comment → Show dialog to Add or Edit: status or comment of SavedViewpoint.
I would like do that with API, but i don't know how to use the API to do this. How can i do it?
Any tips on these will be great help. Thanks in advance.
MinhHN
You can add comments to saveditems whenever they are not readonly (i.e. you are creating a new saved item, or created a copy of the saved item tree to edit it):
 SavedItem.Comments.Add(New Autodesk.Navisworks.Api.Comment(
                               commentText, commentStatus, commentAuthor))
Editing will be along these lines I assume...
Hi ngombault,
Firsts, thank you for the help!
I used code as above, an error occurred when executed: Object is Read-Only.
I tried other code as below, it executed successfully:
Document oDoc = Autodesk.Navisworks.Api.Application.ActiveDocument;
SavedItem oSVP = oDoc.SavedViewpoints.ToSavedItemCollection()[0];
Comment oComment = new Comment("My comments", CommentStatus.Approved);
oDoc.SavedViewpoints.AddComment(oSVP, oComment);
MinhHN
"I used code as above, an error occurred when executed: Object is Read-Only."
-> That's why I specified: "whenever they are not read only (i.e. you are creating a new saved item, or created a copy of the saved item tree to edit it)"
I didn't know about the shortcut you found, but I don't think it will let you edit an existing comment, in which case you'll have to create a copy and replace.
Ah ah, I understand. Thank again!
But, i used the code as above, and edited an existing comment OK ^^
brian.k.smith
@Anonymous :  Thank you - this is working for me!
