Document UpdateFiles() stuck at 51% when running in debug mode
alexisDVJML
alexisDVJML
All in the title 😉
When running Navisworks as a debug process of Microsoft Visual Studio, many things run slower, but sill manageable,
with the exception of UpdateFiles(), stuck for hours while it take just let's say less than 2 minutes when NOT in debug mode.
This make debugging near impossible if such operation is involved.
Any trick?
Thanks.
Main Scientist, Full Stack Developer & When Time Permits Director of IDIGO ► On your marks, Set, Go
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @alexisDVJML ,
Does the issue happen in all files or only in a particular file?
Have you tried by creating a log file to check what is causing the issue?
Could you please provide me the below details?
1) A description of your issue
2) A Complete yet simple non-confidentail sample code
3) A Complete yet simple non-confidentail sample Navisworks file
4) A Complete step by step approach to reproduce the issue
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @alexisDVJML ,
Which Navisworks version are you using?
Naveen Kumar T
alexisDVJML
Navisworks Manage 2020
alexisDVJML
Good suggestions, as usual 😉
Will do more tests on various models and revert.
Thanks.
