DeveloperID for PlugIn
Hi everyone,
I'm developing a PlugIn for Navisworks, but I have to start it from another application.
For the method call I do need a DeveloperID. Can anyone tell me where to find it or how to get it?
ExecuteAddInPlugin(pluginid, parameters);
pluginid = name of plugin and developerID
Thank you in advance.
xiaodong_liang
Autodesk Support
Autodesk Support
Hi @Anonymous,
searching class AddInPluginRecord in NET help, you will find some codes on how to dump plugins collection. It outputs the developer id, name of the plugin. for convenience, I enclosed the code here.
   StringBuilder plugins = new StringBuilder();
         //iterate the plugins and display a list in a message box
         if (Autodesk.Navisworks.Api.Application.Plugins != null &&
            Autodesk.Navisworks.Api.Application.Plugins.PluginRecords != null)
            foreach (Autodesk.Navisworks.Api.Plugins.PluginRecord pr in
               Autodesk.Navisworks.Api.Application.Plugins.PluginRecords)
               //Append the plugin Information
               plugins.Append("Id = ");
               plugins.Append(pr.Id);
               plugins.Append(", Type = ");
               plugins.Append(pr.GetType().ToString());
               plugins.Append(", DeveloperId = ");
               plugins.Append(pr.DeveloperId);
               plugins.Append(", DisplayName = ");
               plugins.Append(pr.DisplayName);
               plugins.Append(", IsEnabled = ");
               plugins.Append(pr.IsEnabled);
               plugins.Append(", IsLoaded = ");
               plugins.Append(pr.IsLoaded);
               plugins.Append(", Name = ");
               plugins.Append(pr.Name);
               plugins.Append(", PluginOptions = ");
               plugins.Append(pr.PluginOptions.ToString());
               plugins.Append(", ToolTip = ");
               plugins.Append(pr.ToolTip);
               plugins.AppendLine();
            //show the list of plugins
            MessageBox.Show(plugins.ToString());
Thanks for your response. But where do I find my own developerID? or can I just simply use any 4 characters?
ulski1
Yes you have to decide your own 4 letters but you have the option to use a GUID instead. By using a GUID you will be more certain that others have not used the same id. As far as I know there is no central register of Autodesk developer 4 letter id, so it is safer to create a GUID
Br
Ulrik
thank you @ulski1. Do you know how I can create a GUID?
ulski1
In the visual studio top menu "tools" there is a built in GUID creator.
Br
Ulrik
