Create and Run Clash Test
Message 1 of 1
Dears,
Inside a plugin, I am creating a new clash test and trying to run it. Using this command "documentClash.TestsData.TestsRunAllTests();" it runs without any errors. However, if I try using "documentClash.TestsData.TestsRunTest(oTest);" where oTest is the newly created instance, it throws "ArgumentException Argument is not in Clash Detective Parameter name: test". No other tests are defined in the model !
What is the cause and possible fix for this error ?
Replies (0)
