Adding a list of ClashResults to a new ClashResultGroup
WalidGLVEK
WalidGLVEK
Hi all,
I would need your help in regards to the above please.
I am writing a code to group clashes based on revit category. I have been successful in getting to a point where I have now a List<ClashResult> that contains the results that I would like to add to a new ClashResultGroup.  Which then will be copied to a clash test copy and then replace the original test.
I have everything working except that when I attempt to add the result or results to the ClashResultGroup, I get an error saying that Childing is read only.
the code I am using to add the results is ClashResultGroup.Childern.Add(clashresult)
How do I tackle this issue? Any ideas?
kind regards,
Walid
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @WalidGLVEK ,
Please try using the below sample code
 private void MyCode(Document doc)
     string groupName = "ClashGroupName1";
     ClashResultGroup group2 = AddOrGetResultsGroup(doc,groupName);
     MoveClashesInsideGroup(doc,group2);
 private ClashResultGroup AddOrGetResultsGroup(Document doc,string groupName)
            string required_GroupName = groupName;
            DocumentClash documentClash = doc.GetClash();
            DocumentClashTests oDCT = documentClash.TestsData;
            ClashTest t = oDCT.Tests[0] as ClashTest;
            //add new group if required
            ClashResultGroup group;
            int groupNdx = t.Children.IndexOfDisplayName(required_GroupName);
            if (-1 == groupNdx)
                ClashResultGroup newGroup = new ClashResultGroup();
                newGroup.DisplayName = required_GroupName;
                oDCT.TestsInsertCopy(t, 0, newGroup);
                group = (ClashResultGroup)t.Children[0];
            else
                group = (ClashResultGroup)t.Children[groupNdx];
            return group;
  private void MoveClashesInsideGroup(Document doc,ClashResultGroup group)
            SavedItemCollection clashes = t.Children;
            int resultsCount = t.Children.Count;
            for (int i = resultsCount - 1; i >= 0; i--)
                SavedItem issue = (SavedItem)t.Children[i];
                ClashResult rt = issue as ClashResult;
                if (null != rt)
                    if (ClashResultStatus.New == rt.Status)
                        oDCT.TestsMove(t, i, group, 0);
For more details,
Please take a look at these below links
https://adndevblog.typepad.com/aec/2012/05/navisworks-net-api-2013-new-feature-clash-1.html
https://adndevblog.typepad.com/aec/2012/05/navisworks-net-api-2013-new-feature-clash-2.html
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
WalidGLVEK
Hi @naveen.kumar.t ,
Thank you so much for the sample code above and the resources provided. They were of great help to me.
kind regards,
Walid
AsankaWaga
Observer
Observer
Thanks, this code is working.
