2D plans
2D plans
2D plans
Is it possible to get the plan and section views (2D drawings) from 3D models in Navisworks Freedom 2017?
ulski1
hi,
just to let you know - you are posting this in the wrong forum - this is the Navisworks api forum (api =  it is for people discussing creating addon programs for Navisworks)
That being said - you can import multiple 3d models and a 2d pdfs into Navisworks as sheet 1,2,3 etc. within Navisworks and then save the whole thing as  nwd and you will be able open the nwd in Navisworks freedom.
More on this in the user manual here: http://help.autodesk.com/view/NAV/2018/ENU/?guid=GUID-4059C73F-457F-45B3-BC26-62866352288E
edit: added image showing 2d pdfs in nwd2d_in_nwd.jpg
br
Ulrik
dgorsman
Navisworks is for reviewing 3D models in context.  It isn't for generating technical drawings from those models.  Further, the Freedom application is a viewer only - it's not intended to do any kind of "stuff" so cannot be customized.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Thank you for your response.
sankara.suthapalli
Dears,
please help me to identify line start point and endpoint in Navis 2D drawing view through Navis API.
How to reach from  start point to endpoint through API code?
