Show only
Search instead for
When a lot of faces are selected for a load or constraint and you are in the edit mode - lots of regeneration of the glyphs is taking place (and slow regenration at that). This needs to be looked at.
We have this with In-CAD. RMB on the loads/constraint/connector/mesh/etc. node and select [Hide All] to turn the visibility off.
Is this what you are looking for?
I noticed you commented on Glyph Visibility forum post. We are working on a solution for this when you are working outside the Autodesk Nastran In-CAD environment all FEA objects are not shown.
We've added a new ability to preview loads/constraints so they are not displayed by default. We've also reduced the default number of glyphs to help with performance on large models. There is also a setting under Default Settings>Display Options to turn off loads and constraints globally. I hope this covers it, but if not, let us know and we can reopen it or open up a new one. Thanks for the feedback!
