Simple 2-part assembly. 1 part fully-constrained, the other part has no constraints or bonding (by intention to test rigid body modes).
Works fine with linear mesh - first 6 modes are <=0. Setting the mesh to parabolic results in fatal error E5001.
Hi Mark,
I will take a look at the model to see what I can figure out.
Just to explain the model to other readers, the assembly consists of a cantilever beam (fully fixed on one end) and a block. As Mark explained, the block is not connected to the beam -- it is completely free. Therefore, a modal analysis should detect 6 rigid body modes at a frequency of 0. Mode 7 should be the first vibration mode of the beam, mode 8 would be the second vibration mode, and so on.
Here are a few things I found.
The work around is to set the "Modal Setup > Extraction Method" to "Subspace Iteration". When this is done, the analysis runs successfully with the parabolic elements.
(edited. I noticed that the description of "thing 2" was incomplete )
Should subspace be the default method then if the parameter RIGIDBODYMODES is set to AUTO or FORCED?
Hi Mark,
I just wanted to make sure the work-around of using the subspace iteration worked for you (and more importantly, for the real model). If so, I will mark this as "solved".
As for the program defaults, I think the developers will attempt to fix whatever the problem is with the default solver rather than using the subspace method.
Hi @John_Holtz,
I am facing similar issue in linear static analysis. I am doing analysis for Pipe (midsurface) with flange (solid). Is there setting in linear static with parabolic mesh?
Thanks, Jayesh
I think the only similarity is the error message. Linear Static versus Normal Modes are completely different analysis types, and the error message is caused by completely different reasons. See my reply to your post https://forums.autodesk.com/t5/inventor-nastran-forum/offset-surface-of-pipe-to-solid-pipe-flange-co....
John
