I'm currently designing a mounting base for a motor running at a constant speed of 1700 rpm for an undergraduate project.
I've already run a linear static stress simulation and a modal analysis. The first two natural frequencies resulted in about 143 Hz and 292 Hz.
However, I wonder how to tell at what frequency of vibration the motor base will be subject to, in order to guarantee a safe operation of the motor.
Can you help me with that?
Thank you,
Roberto
Solved by John_Holtz. Go to Solution.
Hi Roberto,
The mounting base will vibrate due to resonance with the motor if the motor operates at 143 rev/sec (8580 RPM) or 292 rev/sec (17,520 RPM). (In other words, 1 Hz = 1 cycles/sec = 1 rev/sec.) Since the motor is operating at a much lower speed, there should not be a problem with resonance. Unless the motor or its load is severely unbalanced, I think that it is unlikely that the motor will cause any vibration problem.
