Hi all,
I have a fully uncontrained model with i take a modal analysis to do a free-free analysis (see Section 21). in the FEA -Programm of inventor professional the result of the first six ridig body modes are 0. This is correct. If I take Nastran In-CAD only the first 3 (T1,T2,T3) rigid modes are zero or < 1E-03 Hz., the 3 translative modes (R1,R2,R3) are not zero. What is the problem? I attach the out-file of NASTRAN to this post
Regards
Solved by shigeaki.k. Go to Solution.
Solved by Joerg_Grossmann. Go to Solution.
Hello @Joerg_Grossmann,
are you able to show the screenshots of the rigid body modes?
Shigeaki K.
Hi @Joerg_Grossmann,
I am also happy to grab the files from you so I can run them on my side?
Shigeaki K.
Do you have an transfer folder for my model ?
could you try the following?
I will also send you an email via the support portal with instructions on how to attach file(s).
Shigeaki K.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
could you please try with the contact type set to "offset bonding"? You can leave the other settings in the dialogue box as they are.
Shigeaki K.
